hi.. i`m usually on this forum if i need help. and this is one of those time..
i have a SONY HDR-FX1E HD camera...
when i plug it into firewire.. the driver wont initialize in HD mode.. only in DV mode
- so when i set it to DV (the camera) the driver works fine and i can capture in premiere
- but when i set it to HD the AV/C subunit get's a code 28 or code 10 erros and wont load
i`ve heread some people having the same problem.. i need to finish a clip untill tuesday and this is happening now
any hint is apreciated.
thanks
There is more to life than you see!
i searched around and allthough i have service pack 2 installed.. and up to date.. i need to install this
Sony D-VHS Tape device which my windows does not have
quote ""SOUND, VIDEO AND GAME CONTROLLER" category, click NEXT, scroll down to the SONY brand name, then select the "Sony D-VHS Device""
does anyone have this or can send it over? i`m quite mad to have a 6000$ camera which is not working
thanskThere is more to life than you see! -
What version of Premiere? The capture and editing software needs to be HDV capable.
I suggest an upgrade to Premiere Pro Version 2.0 although 1.5 can be made to work. -
yep it's Premiere Pro 2...
it`s not the software .. i didnt get that far...
i found a windwows version (SP2 aswell) that hast those TAPE drivers...
is there a way to extract the files that it uses so i can install them on my pc?
it's so retarded.. some windows versions have them some dont...
thanksThere is more to life than you see!
Mixing all sorts of video (but 1 issue destroys it) HDV flicker
By storhuvve in forum EditingReplies: 7Last Post: 14th Feb 2010, 10:46 -
RAM issue, need urgent help!
By alintatoc in forum ComputerReplies: 2Last Post: 28th Jan 2010, 02:26 -
Importing HDV from a Sony A1U Camcorder. Driver issues possibly.
By Nickbibbo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Oct 2009, 10:43 -
LAN driver issue
By the_shyguy in forum ComputerReplies: 3Last Post: 14th Jan 2008, 01:45 -
URGENT: VOB audio issue
By dshefsky in forum Newbie / General discussionsReplies: 4Last Post: 23rd Sep 2007, 06:54
![Send a message via Yahoo to [.Q.]](images/misc/im_yahoo.gif)
